Hi there :) I am having problems with my rendered pictures, they come out very grainy,.. I have increased for the mr sky portals the "shadow samples to 64" but that doesn't make any difference, I think it has to do with the material? I am using art & design, polished concrete, but in the render you can see,.. that the grains are not only on the floor,.... I 'm using, mental ray, daylight system, mr sky portals, environment map - mr physical sky - mr photographic exposure control, indoor daylight, render settings, final gather on, multiplier 1.0, fg point dencity - 1.0, reys per fig - 200, interpolate over num. fg points - 50, difuse bounces - 0. global ilumination off. any ideas? thanks
What is your render output size?
What is your sampling quality set to? Minimum and Maximum?
What Filter type are you using?
Hi cad64 :)
Output size is - 280x200 ,....
these settings are new to me:
minimum is 1/4 maximum is 4 (this setting is to reduce jagged edges right?)
the filter type is box? ,.... width and height set to 1.0
Ok, those settings are no good if you want a quality render.
The first thing you need to do is decide what size your output needs to be. 8-1/2x11"? 11"x17"? Bigger? Use the print size assistant in the "Rendering" menu. It will allow you to pick your output paper size and resolution, (I generally use 150 DPI). Once you pick your settings, click the "Render Setup" button.
Set Minimum Samples to 4 and Maximum to 16
Set Filter type to Mitchell
But be aware that by using the settings above, your render time will increase substantially.
Thanks for shearing :) I will let you know with the process ;) thanks again
Hi Cad64 :) just to let you know the settings worked perfectly, the images came out very nice, big thanks for sharing your experience, see you soon 8)
