NeilGTi85 Posted August 27, 2008 Share Posted August 27, 2008 Hello all, Yet agian i'm having trouble with clients drawing's!! I've got 2 drawings from the cleint's online drawing register, when I've got both drawing open and try to copy anything from one to the other I get a 5 minute pause.....then eventully it copies accross. I have tried every diffrent way to copy the objects from one to the other but still the same 5 minute wait?? The message I get when it eventully work's is: Command: Duplicate definition of block _DotBlank ignored. Any one got any idea's?? Even if I move all the objects onto layer 0 and purge then try, it still does the same. It only happens with there drawing's, ive tried opening one of there drawings and then a blank drawing and it copies fine.... Cheers Neil Quote Link to comment Share on other sites More sharing options...
dbroada Posted August 27, 2008 Share Posted August 27, 2008 it just means that there is a block called _DotBlank in both drawings, possibly nested within another block. I don't think that wouldbe the cause of your delay. Quote Link to comment Share on other sites More sharing options...
NeilGTi85 Posted August 27, 2008 Author Share Posted August 27, 2008 Ok, I think i'm on the right track.... I went to tool's-block editor, it came up with current drawing and dot_blank. When I clicked on current drawing it paused for a min and then worked, it includes the whole drawing even though its not a block? When I go to the dot_blank block it works fine, no prob's.. How can I delete the block defenition?? As I do not need dot_blank etc Cheers Neil Quote Link to comment Share on other sites More sharing options...
ReMark Posted August 27, 2008 Share Posted August 27, 2008 If the block is no longer a part of the drawing its definition can be eradicated using the Purge command. Quote Link to comment Share on other sites More sharing options...
dbroada Posted August 27, 2008 Share Posted August 27, 2008 if it isn't purging it is probably within another block. When this sort of thing happens to me I..... draw a LONG line at an angle and BMAKE a new definition of the problem block, selecting my recently drawn long line. Accept the redefined block and do a regen. Hopefully you will see the line appear in existing blocks and you have to redefine that block. If nothing happens UNDO and accept defeat. Quote Link to comment Share on other sites More sharing options...
