Hi ,
I was making an important drawing in ACAD2009 and some error occured saying that " AutoCAD needs to close due to some error" , attached is the error report.. how i can i retrieve this file.. i tried recovery, purge,audit and everything i know but not able to open this file.. i even tried in ACAD 2007 .. its giving the same error.
Check tha attachments and Kindly advice...
Thanks
Guru
Error.pdf
acad.txt
Search For Files With Extension 'ac$' Or 'sv$' Around The Time Of Crash. Usually Acacd Creates That File When It Crashes In Certain Situation. If You Find That File, Rename It's Extension To Dwg & Open 7 Check. Sometimes It Also Creats File Call 'undo.tmp' I Have Found Some Of My Lsot Drawings By Searching This Files In The Past.
