e.mounir Posted August 27, 2008 Posted August 27, 2008 The best way to draw match line 1- make match line and brake line with over lab area in each part (note: I will repeated the information in two drawing ) 2- make match line only without brake line ( sometime the match line found in the critical area like expansion joint ) Can any one help me to chose one or tell me another way Regards, Quote
Cad64 Posted August 27, 2008 Posted August 27, 2008 Please don't cross post. I have deleted your other duplicate thread. Can you provide more information about what you're trying to do? Screenshots are also helpful. Quote
chulse Posted August 27, 2008 Posted August 27, 2008 I like to show matchlines as a wide pline sent to the back of the model and screened very light so it doesn't interfere with the detail of the drawing. Quote
e.mounir Posted August 27, 2008 Author Posted August 27, 2008 sory this is my first post find attachd two option dwg.zip Quote
rkent Posted August 28, 2008 Posted August 28, 2008 Wide pline with phantom line type, don't show the same information on both drawings, the match line should start and stop at the same place. Quote
Igopako Posted August 28, 2008 Posted August 28, 2008 rkent is right....I have questions too how can i set my UCS if I want to draw in 2D and 3D in one single model space dwg??? Quote
Cad64 Posted August 28, 2008 Posted August 28, 2008 In Model Space, type VPORTS at the command line to open the "Viewports" dialog. You can choose the setup you want from there. Once you have viewports, you can set your UCS for each one. In the future, it would be better if you start a new thread when you have a question. This thread is about matchlines, not UCS. Quote
Igopako Posted August 28, 2008 Posted August 28, 2008 cool thx, im a newbie next time....ill start a new post.... Quote
