Custom Line Type
Efeezy
*MATCH-LINE_VERTICAL, Line ----MATCH-LINE----MATCH-LINE----MATCH-LINE----
A,.25,-.25,["MATCH-LINE",STANDARD,S=.05,R=90.0,X=-0.15,Y=-0.025],-.25
*MATCH-LINE_HORIZONTAL, Line ----MATCH-LINE----MATCH-LINE----MATCH-LINE----
A,.25,-.25,["MATCH-LINE",STANDARD,S=.05,R=0.0,X=-0.15,Y=-0.025],-.25
  • Replies 42
  • The Buzzard
    12
  • Efeezy
    11
  • alanjt
    7
  • VisDak
    4
Posted Images
*NAME, Line EXAMPLE... ----MATCH-LINE----MATCH-LINE----MATCH-LINE----
A,.25,-.25,["TEXT IN THE LINE",STANDARD,S=TEXT SIZE,R=ROTATION ANGLE OF TEXT,X=-0.15,Y=-0.025],-.25
If You Need More If I Will Look It Up For Ya. I Am Still New To Making Custom Lines So If You Find Anything To Help Please Send Me And I Will Do The Same. Kk
VisDak,
The attached file has tons of lintypes in it. If you place it in your support directory and load this file thru ACAD you could probably view the patterns in the linetype manager. I am sure there are one or two that are similar to what you are showing. Give it a shot.
Thanks Buzzard
i have loaded on my ACAD the linetype only some of the line type are not accur i think his shearching the TSAEC.SHX, an acad fonts:)
Thanks again
Thanks Buzzard
Thanks again
Sorry about that.
All the linetypes and shapes are in this file.
acadlines.zip
Nice Thank Ya Thank Ya. I Will Have To Try Theses Out When I Get Some Free Time. Is The A Modified Custom Line Type That Will Always Face The Horizontal Or Vertical? Some Of My Lines Ended Upside Down.
Omg Nice Nice Thank Ya!!!!
My Favorite Lisp Library Is Off Line Now It Sux Ass... I Got Most Of The Good Stuff I Needed Off Of It.
I know this is kind of off the subject, But since I am cleaning out my folders, Here are some hatch patterns while we are at.
Kidding. :)
I just thought the image was funny.
You're very welcome. :) Enjoy.
Wow,
Thanks for the share Buzzard,:D
Love The Reverslinse. Wish It Autodesk Would Have Got It Right...
No kidding. I finally had to break down and write my own.
Wow,
Did you see the post with the missing linetype shape.
I reposted all the linetypes with the shape and instructions in one zip file.
Ok Do You Have A Lisp So Modlespace And Paper Space Lines Are Consistent. For Example... ----a---- Is Like This In Paperspace But Is Lin This In Modelspace. -a-a-a-a-a-a-a-a-a-a-a-a-a-a-a-a-. Or A Quick Was To Clean Up This Issue?
LTScale
MSLTScale [Edit: Not available in '05]
PSLTScale
I haven't used this since '06, but this an LTScale/PSLTScale reactor.
(defun ChangedLayout (reactor layout / )
 (if (= (nth 0 layout) "Model")
   (progn (setvar "ltscale" (abs (/ (getvar "dimscale") 1))))
   ;else
   (progn (setvar "ltscale" 1.0) (setvar "psltscale" 1))
    );if
(if(not *LayoutLTS*) (setq *LayoutLTS* (VLR-Miscellaneous-Reactor nil
'((:VLR-layoutSwitched . ChangedLayout))))
Here is a program that rotates a complex linetype that is programmed in the lisp and set a layer, color and linweight . You would need to edit this lisp to suit your own needs.
Try it out with the gas line linetype to see what I mean. .
COMPLEX.lsp
