Takes forever to go from model to layout
Hi!
I've a problem with one of the files I'm working with. When I change from model to layout it takes almost a minute for it to change. The file isn't large (2,5MB) and I only have one layout tab. I've done all I know but nothing helps...
All I know means:
-pu All
-pu Regapps
audit
scalelistedit
Any suggestions??
No other CAD related problems?
No problems with other programs?
Is this a standalone computer?
how about looking into system variable LAYOUTREGENCTL ?
ReMark: No other CAD related problems or problems with other programs. The file is located on a server at work. But I think I've solved the problem:
NBC: You might be on to something...LAYOUTREGENCTL was set to 0 and I changed it to 2. Now I can change between model and layout without any delay. I'm not sure what LAYOUTREGENCTL does, havn't used that variable before and reading the help didn't made me any wiser. But it seems to be working so thanks for the help.
