having trouble with a linetype
it is an electrical linetype we use all the time with no problems
---E---E---E---E
I import it into my drawing then matchprop the polyline. It changes color and layer and linetype but displays as solid
I draw a pline identical to the one that displays as solid. I matchprop no problem
I trace over the stubborn lines with new plines ---E---E no problem
I erase the stubborn lines thinking the problem solved
I zoom out and they appear solid. I zoom back in and they stay that way. I did a regenall with no help
The confusing thing is that the original line I imported is not effected. It displays correctly
It sounds like the problem linetype has some form of z values (i.e. elevation) attributed to it.
  • 6 years later...
Attributed Text In Linetypes:
Is it still possible to attribute text in a linetype?
Early Versions of Cad Version 11/12, I believe had the basic ability to generate an attributed line type.
Thoughts
MacGyver
Attributed Text In Linetypes.docx
Notice this thread is almost 7 years old, and not relevant? You have a modern program, tried it with that? The Giant Spammer Eye is upon you.
