WCCSAM Posted May 13, 2010 Posted May 13, 2010 Using Autocad 2010... Heres what I am trying to do... I have a block that has attributes (so i don't want to explode it) but I need this block to have a dimension line attached. So when I insert it I can extend/trim the dimension line to demonstrate extents. Is there any way to have a block like this so when I insert it the dimension line can be adjusted? Quote
alanjt Posted May 13, 2010 Posted May 13, 2010 Maybe something like this.... The length will update as the block scale changes. TEMP.dwg Quote
WCCSAM Posted May 13, 2010 Author Posted May 13, 2010 mmmm Not really.... The scale of the block does not change I just need to be able to extend the dimension part of the block. Quote
WCCSAM Posted May 13, 2010 Author Posted May 13, 2010 What function in dynamic blocks will perform this function? Quote
alanjt Posted May 13, 2010 Posted May 13, 2010 Stretch, then you use a field to display the length (as I displayed in my example). Quote
