joewaianae Posted May 13, 2010 Share Posted May 13, 2010 Can you wipeout a circle or oval, and if not, how can i make it so that I can? Quote Link to comment Share on other sites More sharing options...
Pablo Ferral Posted May 13, 2010 Share Posted May 13, 2010 Wipeouts have to be polygons, so you could create a polygon with enough facets to approximate a circle, or use a solid hatch. Quote Link to comment Share on other sites More sharing options...
joewaianae Posted May 13, 2010 Author Share Posted May 13, 2010 that will be what i do for now, i was just wondering thanks. Quote Link to comment Share on other sites More sharing options...
ScribbleJ Posted May 13, 2010 Share Posted May 13, 2010 You may know this already so don't take this as an insult to your knowledge. I know I sometimes forget some of the basics. Use the Polygon command and give it like 60 sides then select the center of your circle. Wallah! A polygon disguised as circle. Quote Link to comment Share on other sites More sharing options...
joewaianae Posted May 14, 2010 Author Share Posted May 14, 2010 thanks scribblej, exactly what i am doing Quote Link to comment Share on other sites More sharing options...
