rengised Posted May 13, 2010 Posted May 13, 2010 Hi friends, anybody can advise me regarding the publish using cute pdf. when i publish its not automatically save. if i publish multiple drawing using my page setup in pdf i need to type the name one by one. any options? Quote
f700es Posted May 13, 2010 Posted May 13, 2010 Not a perfect solution but you could always publish to a multi-page dwf and then use the dwf viewer to print to a multi-page PDF. Quote
rengised Posted May 13, 2010 Author Posted May 13, 2010 Thanks for the reply, but our client required us to convert all the drawings in pdf as individuals. Thnks:) . Quote
MikeScott Posted May 13, 2010 Posted May 13, 2010 I use Primo PDF.. It will append pdf's together if use the same filename (it warns you first), but you still do it tab by tab, EXACTLY like you're plotting (but instead of the normal printer, you choose Primo PDF instead) Nice thing about it, besides being free, is that it works as a PDF printer in any program you print from. Quote
alanjt Posted May 13, 2010 Posted May 13, 2010 I use Primo PDF.. It will append pdf's together if use the same filename (it warns you first), WHAAAAAAAAA!?!?! Quote
f700es Posted May 13, 2010 Posted May 13, 2010 Thanks for the reply, but our client required us to convert all the drawings in pdf as individuals. Thnks:) . So each drawing has to be a separate PDF? Yuck! Quote
Tankman Posted May 13, 2010 Posted May 13, 2010 Wrong forum for Louis Vuitton or does he clothe AutoCAD OP's? Quote
alanjt Posted May 13, 2010 Posted May 13, 2010 Wrong forum for Louis Vuitton or does he clothe AutoCAD OP's? Only the ones with an insane amount of money to burn. Quote
