alijahed Posted May 13, 2010 Posted May 13, 2010 Hi All and thanks for being really helpful as always, I am trying to use AutoCAD commands like "_insert" in LISP. my problem is I don't understand how to control or answer the questions coming afterward: specify insertion point or [basepoint/scale/x/y/z/rotate] Is there any source for giving me information about the syntax of different commands? Cheers Ali Quote
harrison-matt Posted May 14, 2010 Posted May 14, 2010 The syntax for using Command Calls is like the flow of the command being executed. Example: (defun C:test () (setq blkname (getstring "\nWhat is the name of the block you would like to insert?")) (setq point (getpoint "\nPick insertion point")) (command "-insert" blkname point 1 1 0) (princ)) This asks you the name of the block (you could use any block name in your support path, (you don't need the .dwg extension)), the insertion point then inserts the block at 1 xscale 1 yscale and 0 rotation. the negative infront of insert runs the command at the prompt. I suggest you have a look at the Help files for more information though. I hope that helps. Quote
alanjt Posted May 14, 2010 Posted May 14, 2010 Just think how the command runs and that's how you emulate it. eg. Command: -insert Enter block name or [?] <A$C71D65DF4>: temp Units: Unitless Conversion: 1.00000000 Specify insertion point or [basepoint/Scale/X/Y/Z/Rotate]: [color=Red](I picked a point here)[/color] Enter X scale factor, specify opposite corner, or [Corner/XYZ] <1>: 2 Enter Y scale factor <use X scale factor>: 2 Specify rotation angle <0>: 45 Keep in mind that the following code specifies and assumes existence of a block called "TEMP". In code, using PAUSE to receive point from user: (command "_.-insert" "temp" PAUSE 2. 2. 45.) In code, using GetPoint to receive point and then executing insert command. (defun c:TEst (/ pt) [color=Red]; define function and localize variables[/color] (if (setq pt (getpoint "\nSpecify insertion point: ")) [color=Red]; get point from user[/color] [color=Red] ;; the IF is so the program will ONLY proceed if the point is valid (not nil)[/color] (command "_.-insert" "temp" "_non" pt 2. 2. 45.)[color=Red] ; insert block[/color] [color=Red];; I added the "_non" to ignore any running osnaps[/color] ) (princ) ; close quietly ) In a situation where you just want to emulate a carriage return, use "". Hope this helps. Quote
alanjt Posted May 14, 2010 Posted May 14, 2010 Oop, sorry Harrison. I wish it would tell you when another user has posted before you submit. Oh well. Quote
alijahed Posted May 14, 2010 Author Posted May 14, 2010 Thank you very much for your help guys, can you please help me with this: I want to insert "ssw1" in (0,0,0) with scale factor x/y/z/ equal to 1 and rotate 0 and also explode when inserted. (command "_insert" "ssw1" ?????) sorry guys but I confused Cheers Ali Quote
alanjt Posted May 14, 2010 Posted May 14, 2010 Did you read through my examples? (command "_.-insert" "temp" PAUSE [color=Red]2.[/color] [color=Lime]2.[/color] [color=Magenta]45.[/color]) X Value Y Value Rotation Quote
alijahed Posted May 14, 2010 Author Posted May 14, 2010 Did you read through my examples? (command "_.-insert" "temp" PAUSE [color=Red]2.[/color] [color=Lime]2.[/color] [color=Magenta]45.[/color]) X Value Y Value Rotation Yahoooo great I am so excited!!! mate what is "_." in front of _insert? and I inserted my block by the following code in (1508.1524,182.9885,0) point but I don't understand how?! I want to insert it in (0,0,0). Can you please help me with this. ?!@@#!@##$ I open another file and did the same thing and the block inserted right in to (0,0,0)!!! But I don't understand how?! I also attached what I received from AutoCAD. (command "_insert" "ssw1" 0. 1. 1. 0.) Cheers _insert Enter block name or [?]: ssw1 Units: Millimeters Conversion: 1.0000 Specify insertion point or [basepoint/Scale/X/Y/Z/Rotate]: 0.000000000000000 Enter X scale factor, specify opposite corner, or [Corner/XYZ] : 1.000000000000000 Enter Y scale factor : 1.000000000000000 Specify rotation angle : 0.000000000000000 Ali Quote
harrison-matt Posted May 14, 2010 Posted May 14, 2010 Oop, sorry Harrison. I wish it would tell you when another user has posted before you submit. Oh well. Don't even worry about it, i was trying to just see if i could help out for once! Your response was more constructed with examples anyway! By the way my VL has been improving since you helped last! Alan, you should see if you can't help me here though...http://www.cadtutor.net/forum/showthread.php?t=47982 Thanks! Quote
alanjt Posted May 14, 2010 Posted May 14, 2010 _ is to ignore any language differences (Autocad originally written in English) . is to ignore any redefining of a command. To insert at 0,0,0, you could a string (command will accept), but the best way is to feed it a list. eg. (command "_insert" "ssw1" '(0. 0. 0.) 1. 1. 0.) Examine what happens when you pick a point with the following: Command: (getpoint) (-20.7212 22.1642 0.0) Quote
alanjt Posted May 14, 2010 Posted May 14, 2010 Alan, you should see if you can't help me here though...http://www.cadtutor.net/forum/showthread.php?t=47982 Thanks! Check the other thread. :wink: Quote
