Exoteric Posted May 17, 2010 Share Posted May 17, 2010 Ok, I made this gear with bearings inside in CAD/2D platform. My views are on front view and side view. I just want to represent it on perspective view. How can I do the arrays for it? My perspective view from the base line is 35 degrees. EDIT: I am using AutoCAD 2007. BTW. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 18, 2010 Share Posted May 18, 2010 A simple look at it in 3d vpoint 1,1,1 If you have drawn the gear in 2d then make the edge a polyline and extrude it to the height of the gear making it a solid. You will need to Subtract the bearing hole which is a second solid taken away from the gear body extrude a circle Hope this helps Quote Link to comment Share on other sites More sharing options...
