I have been receiving often this message when I go to File/open
"Application does not support Windows Forms just-in-time (JIT)
debugging. Contact the application author for more
information."
It does not happend all the time
Any switch I should turn on/off
Please help
HR
As I recall the full error message is fairly long. But right up near the top there should be a line that starts off reading...
Could not load file or assembly...
It is what comes after those words you need to look at since the name of the file that is causing the problem should be listed.
  • 5 years later...
Hai Friends,
I had also faced the same problem.
____________________________________________________
information.
this appears when i use NETLOAD (ENTER)-(BROWSE)DGNPURGE(ENTER)
THEN --- DGNPURGE (ENTER)
Please help:(:!::!::!:
If you are purging DGN Lintypes, AFAIK 2015 has the DGNPurge included in the standard PURGE command.
Hard to tell what exactly is giving you the message without more information.
