AutoNewbie Posted August 28, 2008 Share Posted August 28, 2008 Do I have to re-define fields for new sheet sets? I'm trying to use a sheet that already has the fields defined as the source file, but when I look at properties for the new set none are defined. I'd like to be able to start a new sheet set based on an existing layout that already contains defined fields, and have the sheet set manager aware of the fields....can I do that? Quote Link to comment Share on other sites More sharing options...
rustysilo Posted August 28, 2008 Share Posted August 28, 2008 I believe that's when you want to create a new sheet set "from an example sheet set" as opposed to creating one "from existing drawings". Quote Link to comment Share on other sites More sharing options...
