Hi guys!
Just wondered if anyone can answer this,
I have 2 lines on AutoCAD LT 2009 both of which I've drawn at 32degrees. Now, hoping they would be parallel i continued my drawing only to find later that they're a differenct distance apart at 1 end compared to the other? :o
Just wondered if anyone had come accross this before? And why it does it? (is it drawing it possibly just a couple of seconds out?)
I've attached the lines on a .dwg as an example, hopefully someone can figure it out!
Thanks in advance! :)
angle example.dwg
Try changing the precision of your Angle Units; then you will notice that the yellow line is not at 32 degrees
ah! damn, on the original drawing i took it from the majority of my lines follow the same angle as the yellow 1, but the grey 1 is the 1 i needed them to follow! :(
ok thanks! figured 1 might be out!
any chance you could just remind me how to change the precision of the units?
it's ok! found it again! Thanks for the help NBC!! :D
