Lee Mac: Thanks but that only seems to connect with a 2D Polyline. I was looking for a 3D polyline to connect points with varying z values.
  • Replies 62
  • alanjt
    29
  • Lee Mac
    12
  • stevesfr
    11
  • Demesne
    6
Posted Images
It is a 3dPolyline. When you list a 2d or 3dpolyline, it will just say 'Polyline'.
Ahhh! I see.
My ride is late...
(defun c:OC (/ _sel lst pt line)
 ;; Connect objects (by insertion point)
 ;; Alan J. Thompson, 05.22.10
 (vl-load-com)
 (defun _sel (pnt msg / gr e pt)
   (while (and (setq gr (grread T 15 2))
               (/= (car gr) 25)
               (not (vl-position (cadr gr) '(13 158)))
               (not e)
     (redraw)
     (and pnt (grdraw (trans pnt 0 1) (cadr gr) 1 -1))
     (princ (strcat "\r" msg))
     (if (and (eq 3 (car gr))
              (setq e (ssget (cadr gr)))
              (setq e (entget (ssname e 0)))
              (not (wcmatch (cdr (assoc 0 e)) "*LINE*,ARC,*TEXT*"))
              (setq pt (cdr (assoc 10 e)))
       pt
       (setq e nil)
 (if (car (setq lst (list (_sel nil "Select object: "))))
   (while (setq pt (_sel (car lst) "Select next object: "))
     (if (equal pt (car lst))
       (alert "Same object as previous!")
       (if line
         (vla-put-coordinates
           line
           (AT:PointList->Array (apply (function append) (reverse (setq lst (cons pt lst)))))
         (setq line (vla-Add3DPoly
                      (AT:ActiveSpace)
 (redraw)
(defun AT:PointList->Array (lst)
 ;; Convert point list (must be appended first) to array
 ;; Alan J. Thompson, 09.16.09
 (if (vl-consp lst)
   (vlax-Make-Variant
     (vlax-SafeArray-Fill (vlax-Make-SafeArray vlax-vbDouble (cons 0 (- (length lst) 1))) lst)
(defun AT:ActiveSpace (/)
 ;; Defined ActiveSpace
 ;; Alan J. Thompson, 10.12.09
 (if (or (eq acmodelspace
             (vla-get-activespace
               (cond (*AcadDoc*)
                     ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
         (eq :vlax-true (vla-get-mspace *AcadDoc*))
   (vla-get-modelspace *AcadDoc*)
   (vla-get-paperspace *AcadDoc*)
