Hey everyone,
Ive got the following problem:
I want to make a dynamic block, made of multiple rectangles, and some other blocks. when I stretch the dynamic block, it stretches the rectangles perfectly, but the blocks remain the same size.. is it possible to stretch the blocks as well?
Ive tried to make the other blocks into dynamic blocks as well, but that didnt work...
I attached an example of the problem.
Dyn_block.dwg
Blocks are not able to be stretched, you may try using the scale command in the dynamic block
Instead of putting nested blocks within the Dynamic block, try putting stretch parameters on the objects.
I agree - why make that large rectangle a block at all. Just explode it and remake the block with a stretch parameter that includes all of the retangles?
Eventually the i'll turn the blocks into dynamic blocks.
I want to be able to explode them out of the dynamic block..
but if its impossible ill try to find another way, thanks for the replies!
