I did a search and didn't seem to find anything on this. I draw architectual floor plans and create column lines with a circle on the end of the line. I then insert text in the circle. usually a single digit or alpha character. The trouble is I often spend too much time trying to get the text to fit nicely in the center of the circle. Can anyone help me with this?
  • Replies 29
  • ReMark
    9
  • alanjt
    7
  • gsksun4
    7
  • josemukalel
    3
Middle (Middle center) justify the text and use the center osnap of the circle as the insert point for the text.
One more, just for fun...
(defun c:TIC (/ label pt dist)
 ;; MText label witin circle
 ;; Alan J. Thompson, 05.22.10
 (vl-load-com)
 (if (and (/= "" (setq label (getstring t "\nSpecify label: ")))
          (setq pt (getpoint "\nSpecify center point: "))
          (setq dist (getdist pt "\nSpecify radius of circle: "))
   ((lambda (p)
      (entmakex (list '(0 . "CIRCLE") (cons 10 p) (cons 40 dist)))
      ((lambda (text)
         (vla-put-AttachmentPoint text 5)
         (vla-put-InsertionPoint text (vlax-3d-point p))
        (vla-addMText
          (if (or (eq acmodelspace
                      (vla-get-activespace
                        (cond (*AcadDoc*)
                              ((setq *AcadDoc* (vla-get-activedocument (vlax-get-acad-object))))
                  (eq :vlax-true (vla-get-mspace *AcadDoc*))
            (vla-get-modelspace *AcadDoc*)
            (vla-get-paperspace *AcadDoc*)
          (vlax-3d-point p)
          0.
          label
     (trans pt 0 1)
(defun c:TCL (/ obj label)
 ;; Label selected circle with MText
 (vl-load-com)
 (if (and (setq obj (car (entsel "\nSelect circle: ")))
          (or (eq "AcDbCircle" (vla-get-objectname (setq obj (vlax-ename->vla-object obj))))
              (alert "Invalid object!")
   ((lambda (p)
      ((lambda (text)
         (vla-put-InsertionPoint text p)
        (vla-addMText
                        (cond (*AcadDoc*)
          p
          0.
          label
     (vla-get-center obj)
Bill:
It was right there under your nose the entire time. You just had to look on your Tool Palettes on the Annotation tab. The very first entry at the top called Tag - Imperial is a number within a circle. The number is an attribute.
Seek and ye shall find.
I'm running 2010 too.
Bill:
ReMark, another good find. Would like to know why the text in the circle doesn't take on the font set in the drawing? Or how can I set it to? It doesn't list out a font, and I don't want to explode it, but just to see what font lists out I did. No font listed, but style lists out as Tohoma.
Glenn
2009LT
It's an attribute. The font can be reset.
Bill:
Actually, the Dynamic one I created above (with scale parameter on the circle) was taken from that block and modified. :lol:
OK...if you really, really don't want to reset the text style option every time you insert one of these symbols this is a kludge-type workaround.
The font used is called Tahoma. Open the Text Style dialog window and change the font style to something else. Finish by clicking Set Current then OK. The font style change should be reflected in any symbol you have already inserted and in any new ones you insert in the future.
Can you please explain? I tried in properties mgr, but no luck.
The font used is called Tahoma. Open the Text Style dialog window and change the font style to something else. Finish by clicking Set Current then OK. The font style change should not be reflected in any symbol you have already inserted and in any new ones you insert in the future.
Why not just edit, rename and put back in Toolpalettes?
I'm trying to change the attribute in the block editor, but no luck with the font.
I also changed the font in the text style mgr, then inserted another tag, but got same results.
The Text Options tab. Text style. Apply. Done.
No text options tab to be found in block editor or style mgr. LT has let me down again.
Semantics. You're right. The word "not" was inadvertantly included. Good catch. :)
Well ReMark, I appreciate your input. I can change the font and style in the manager, but that block still comes up Tahoma after doing so. Other new text has the font change. That's Mtext and Dtext. I won't waste any more of your time over this. I'm just cursed. Heh.
Thank you again friend.
Glenn
I've tested it twice now and got it to work. You only need to change the font name you want AutoCAD to substitute for the style Tahoma. You do not change the style.
