ruksi Posted October 2, 2010 Posted October 2, 2010 asos2000 & Tiger, for both of u thanks alot, Again i am faceing problem? I use this lisp in my co-ordinate drawing, but its not comeing actule co-ordinate, I check with "UCS" allso thats in correct way, my drawing units are milimeters, table is show {xxxxxxx'-xxx"} like that, So I think it besaue of unit problem, PLEASE HOW TO SOLVE THE ABOVE MATTER This lisp file is very good Quote
ruksi Posted October 6, 2010 Posted October 6, 2010 Dear friends,:( I have try your lisp file its come like this wrong codinate, I include hear correct coordinate of same points (actual (x/y) coord) please!!!!!!! tell me how to correct it? co-ordinate.pdf Quote
stevesfr Posted March 20, 2012 Posted March 20, 2012 I think that he wants the lisp to be at this sequance - Pick a point - Insert a point and a sequencial number - at end create a table has the point number and N and E for So See this ;; local defun (defun make-tablestyle ( name desc txtstyle h1 h2 h3 / tblstyle adoc) (or (vl-load-com)) (setq tblstyle (vla-addobject (vla-item (vla-get-dictionaries (setq adoc (vla-get-activedocument (vlax-get-acad-object))) ) "Acad_Tablestyle" ) name "AcDbTableStyle" ) ) (setq acmCol (vla-getinterfaceobject (vlax-get-acad-object) (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2)))) (vla-put-name tblstyle name) (vla-put-headersuppressed tblstyle :vlax-false) (vla-put-titlesuppressed tblstyle :vlax-false) (vla-put-description tblstyle desc) (vla-put-flowdirection tblstyle 0) (vla-put-bitflags tblstyle 1) (vla-put-horzcellmargin tblstyle (/ h3 5)) (vla-put-vertcellmargin tblstyle (/ h3 5)) (vla-settextstyle tblstyle 7 txtstyle) (vla-settextheight tblstyle 1 h3) (vla-settextheight tblstyle 4 h2) (vla-settextheight tblstyle 2 h1) (vla-setrgb acmCol 204 102 0) (vla-setgridcolor tblstyle 63 7 acmCol) (vla-setgridvisibility tblstyle 63 7 :vlax-true) (vla-setgridlineweight tblstyle 18 7 aclnwt009) (vla-setgridlineweight tblstyle 45 7 aclnwt050) (vlax-release-object acmCol) ) ;; local defun (defun draw_table (ins_point title header_list table_data / acmcol acsp adoc axss cnt col columns dht lst_count objtable row rows ) (if (< (atof (getvar "ACADVER")) 16.0) (alert "This routine will work\nfor versions A2005 and higher") (progn (alert "\tBe patience\n\tWorks slowly") (or (vl-load-com)) (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object)))) (or acsp (setq acsp (if (= (getvar "TILEMODE") 0) (vla-get-paperspace adoc) (vla-get-modelspace adoc)) ) ) (make-tablestyle "Point Data" "Symbol table" "Standard" 10.0 10.0 12.0) (setq acmCol (vla-getinterfaceobject (vlax-get-acad-object) (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2)))) (setq dht (getvar "dimtxt")); text height, change by suit (setq lst_count nil) (setq columns (length (car table_data)) rows (length table_data) ) (setq objtable (vlax-invoke acsp 'Addtable ins_point (+ 2 rows) columns ;; rows height (change by suit): (* dht 1.667);28 ;; columns width (change by suit): (* dht 8.333);50 ) ) (vla-put-regeneratetablesuppressed objtable :vlax-true) (vla-put-layer objtable "0") (vla-put-titlesuppressed objtable :vlax-false) (vla-put-headersuppressed objtable :vlax-false) (vla-put-horzcellmargin objtable (* dht 0.5)) (vla-put-vertcellmargin objtable (* dht 0.5)) (vla-settextstyle objtable 2 "Standard") (vla-settextstyle objtable 4 "Standard") (vla-settextstyle objtable 1 "Standard") (vla-setrowheight objtable 2 (* dht 1.5)) (vla-setrowheight objtable 4 (* dht 1.25)) (vla-setrowheight objtable 1 (* dht 1.25)) (vla-settextheight objtable 2 (* dht 1.25)) (vla-settextheight objtable 4 dht) (vla-settextheight objtable 1 dht) (vla-put-colorindex acmcol 256) (vla-put-truecolor objtable acmcol) (vla-setcolumnwidth objtable 0 (* dht 10)) (vla-setcolumnwidth objtable 1 (* dht 15)) (vla-setcolumnwidth objtable 2 (* dht 15)) (vla-setcolumnwidth objtable 3 (* dht 15)) (vla-put-colorindex acmcol 2) (vla-settext objtable 0 0 title) (vla-setcelltextheight objtable 0 0 (* dht 1.5)) (vla-setcellcontentcolor objtable 0 0 acmcol) (vla-put-colorindex acmcol 102) (setq col 0 row 1 ) (foreach a header_list (vla-settext objtable row col a) (vla-setcelltextheight objtable row col (* dht 1.25)) (vla-setcellcontentcolor objtable row col acmcol) (setq col (1+ col)) ) (vla-put-colorindex acmcol 40) (setq row 2 col 0) (setq cnt 1 row 2) (foreach i table_data (setq col 0) (foreach a i (if (= col 0) (progn (vla-settext objtable row col a) (vla-setcellalignment objtable row col acMiddleLeft)) (progn (vla-settext objtable row col (rtos a 3 2)) (vla-setcellalignment objtable row col acMiddleCenter)) ) (vla-setcellcontentcolor objtable row col acmcol) (setq col (1+ col))) (setq row (1+ row)) ) (vla-put-regeneratetablesuppressed objtable :vlax-false) (vl-catch-all-apply (function (lambda () (progn (vla-clear axss) (vla-delete axss) (mapcar 'vlax-release-object (list axss objtable)) ) ) ) ) (vla-regen adoc acactiveviewport) (alert "Done") ) ) (princ) ) ;; local defun (defun draw_textfromlist (data_list txt_height / ) (or (vl-load-com)) (or adoc (setq adoc (vla-get-activedocument (vlax-get-acad-object)))) (or acsp (setq acsp (if (= (getvar "TILEMODE") 0) (vla-get-paperspace adoc) (vla-get-modelspace adoc)) ) ) (mapcar (function (lambda(x) (vlax-invoke acsp 'AddText (car x) (list (cadr x)(+ (caddr x)(* txt_height 0.785))(last x)) txt_height))) data_list ) (princ) ) ;; main part (defun C:PNT (/ ans fd fname lbl loop num pfx pt pts) (initget "Y N") (setq ans (getkword "\nDo you want to add prefix? (Y/N) <Y> : ")) (if (not ans)(setq ans "Y")) (if (eq "Y" ans) (setq pfx (getstring T "\nEnter the prefix to add: "))) (setq num (getint "\n Enter the initial number <1> : ")) (if (not num)(setq num 1)) (setq pt (getpoint "\nDigitize the first point :") lbl (if pfx (strcat pfx (itoa num))(itoa num)) pts (cons (cons lbl pt) pts)) (setq num (1+ num)) (while (setq pt (getpoint "\nDigitize the next point [hit Enter to exit] :" pt)) (if (null pt)(setq loop nil)) (setq lbl (if pfx (strcat pfx (itoa num))(itoa num))) (setq pts (cons (cons lbl pt) pts)) (setq num (1+ num)) ) (setq pts (reverse pts)) (draw_textfromlist pts (getvar "dimtxt"));<-- text height, change by suit (initget "E A") (setq ans (getkword "\nDo you want to export point to Excel Or draw Acad table? (E/A) <E> : ")) (if (not ans)(setq ans "E")) (if (eq "E" ans) (progn (setq fname (getfiled "* Set Name Of New Excel File *" "" "xls" 1)) (setq fd (open fname "w")) (princ "Point label\tX coord.\tY coord.\tZ coord.\n" fd) (foreach i pts (princ (strcat (car i) "\t" (rtos (cadr i) 3 2) "\t" (rtos (caddr i) 3 2) "\t" (rtos (last i) 3 2) "\n") fd) ) (close fd) ) (progn (setq ipt (getpoint "\nPick insertion point of table: ")) (draw_table ipt "Title goes here" '("Point No." "X coord." "Y coord" "Z coord.") pts) ) ) (princ) ) (princ "\n\t\t***\tType PNT to export points to Excel or to Acad table\t***") (princ) This works fine, except I need a clue on how to get table to report as pt#, North, East, Elev. instead of Pt#, East, North, Elev. I was able to get the data to xls file to be reversed, but not the table. Need your suggestion on what lines to revise. TIA Steve Quote
