I use AutoCAD 2011 for few weeks now.
After a few days ago it became unstable, the program start to "hang" at startup.
The status bar, on the bottom of the AutoCAD window, "hang" on 39%.
The OS (Windows 7) state that there is no responding from the program.
I read all the forums I found on this issue, among them was an article published by Autodesk support, ID: TS1076266 from 2007-Oct-29, its about "Program appears to freeze or hang during startup".
This article is for AutoCAD 2008 but it looks the same on 2011.
I have tried every solution I saw on the forums and on this article, like "un-checking for publisher's certificate revocation", re-install, repair etc…
How can I solve this problem? There is no way to open the AutoCAD at all.
I will be grateful for any help regarding this matter.
My PC spec. is:
Windows 7 x64 ultimate
AutoCad 2011 x64
GPU – fx 1800
CPU – i7-960
RAM – 6Gb
Thank you in advanced
Keren
  • 3 months later...
Hi Keren
I have the same problem , same specs
How did you finally solve your problem ?
The post you are responding to is over a year old and the person who posted never returned to CT and posted anything else again as evidenced by the post count of "1". I don't think keren84 is going to respond any time soon. I hope you have a lot of patience.
I suggest you start your own new thread and provide all your pertinent details. By the way, your computer details say Windows Vista while Keren's list Windows 7. I'm assuming there are some other differences too.
  • 2 months later...
Hi Remark,
our Client have the same issue.. we are a reseller in the Philippines. i wonder if there is a solid solution that solved this issue.. I've been thru different treads & workaround in Autodesk website but still no luck..
these are the Log infos in the Log File.
2812 2010/12/16 08:09:34 Reason=Fatal error
2812 2010/12/16 08:09:34 ComputerName=KDTW137
2812 2010/12/16 08:09:34 OS=5.1.2600.Service Pack 3
2812 2010/12/16 08:09:34 File=AdlmIntLicense.cpp,Line=1004
2812 2010/12/16 08:09:34 VendorID=10 [CASCADE]
2812 2010/12/16 08:09:34 VendorError=6 [Error reading decrypted information]
4052 2010/12/16 08:38:29 Reason=Fatal error
4052 2010/12/16 08:38:29 ComputerName=KDTW137
4052 2010/12/16 08:38:29 OS=5.1.2600.Service Pack 3
4052 2010/12/16 08:38:29 File=AdlmIntLicense.cpp,Line=1004
4052 2010/12/16 08:38:29 VendorID=10 [CASCADE]
4052 2010/12/16 08:38:29 VendorError=6 [Error reading decrypted information]
112 2010/12/16 09:02:11 Reason=Fatal error
112 2010/12/16 09:02:11 ComputerName=KDTW137
112 2010/12/16 09:02:11 OS=5.1.2600.Service Pack 3
112 2010/12/16 09:02:11 File=AdlmIntLicense.cpp,Line=1004
112 2010/12/16 09:02:11 VendorID=10 [CASCADE]
112 2010/12/16 09:02:11 VendorError=6 [Error reading decrypted information]
2004 2010/12/16 09:07:05 Reason=Fatal error
2004 2010/12/16 09:07:05 ComputerName=KDTW137
2004 2010/12/16 09:07:05 OS=5.1.2600.Service Pack 3
2004 2010/12/16 09:07:05 File=AdlmIntLicense.cpp,Line=1004
2004 2010/12/16 09:07:05 VendorID=10 [CASCADE]
2004 2010/12/16 09:07:05 VendorError=6 [Error reading decrypted information]
i has been 1 week of punishing research, looking for solution in this issue, but until now, no luck..
if there is anyone who has same issue & has solved it.. we would really appreciate if it will be shared to us..
thank you!
Absolutely no luck in finding a solution? It may be time to wipe the drive and start over then as much as I hate to say it.
Have you tried disabling your antivirus program?
So this client has never successfully opened AutoCAD not even once?
  • 1 month later...
they have used AutoCAD for a week and then this error occurs.. we are now working on its hardware and will try to evaluate if this maybe the cause of the hang-ups.. i'm praying that we can solve it by this procedure. because its been punishing us for almost a month.. i'll update you if we solve it..
Look for the WSCommCntr2.exe in the Windows Task Manager. Mine was doing this and killing this process seemed to fix it for me.
Acad 2011 and Win Vista here
