I had a look around and couldn't find a solution to this, there has been unanswered posts about it aswell so I'm just calling out for help again.
Here is what I have so far;
^c^cfiledia;0;open;c:\example\symsht-2.dwg;filedia;1;
and this is what I get
Command:
Command:
Command: filedia
Enter new value for FILEDIA : 0
Command: open
Command: c:*Cancel*
Reason I'm wanting to do this is, I'm not sure if there is a way to hyperlink something into my palettes so that I can open up a drawing from the palette. I also want to be able to use on LT versions. So lisps are out of question....:cry:
Try:
^c^cfiledia;0;open;"c:/example/symsht-2.dwg";filedia;1;
From the help:
NoteWhen specifying a directory path, you must use a slash (/) or two backslashes (\\) as the separator, because a single backslash has a special meaning in AutoLISP.
Thank you Pablo for your fast reply but it's still going
Command:
Command:
Command: filedia
Command: open
Command: "c:\example\symsht-2.dwg"
Unknown command
""c:\example\symsht-2.dwg"". Press F1
for help.
Command: filedia
Enter new value for FILEDIA : 1
Hyperlinks aren't a feature in AutoCAD LT?
:?:?Hi friends,
I am also need this solution. how can open a drawing using macro? please solve if possible.......................thank you:?:?:?
Are you still using 'Back slashes' instead of 'Forward slashes'?
nar I used forward slashes I just paste the wrong quote lol mm
This is what I get when I use this
Command:
Command:
Command: filedia
Command: open
Command: "c:/example/symsht-2.dwg"
Unknown command ""C:/EXAMPLE/SYMSHT-2.DWG"". Press F1 for help.
Command: filedia
Command: FILEDIA
  • 1 month later...
try
^c^cfiledia 0 open "c:/example/symsht-2.dwg" filedia 1
if it doesn't work change / to \
You will have problems with "c:\example\symst 2.dwg" the space in the file name causes problem. There is an answer but not with LT
I have just put-
^C^Cfiledia;0;open;"G:/Server1staff/Drawings/JFNL/project/drawings/WELDED ASSY.dwg";filedia;1;
onto a button in LT2002 and it works fine, even with the space in the drawing name.
The Autocad text window shows-
Command: filedia
Command: open
Enter name of drawing to open
Opening an AutoCAD LT 2000/AutoCAD 2000 format file.
Regenerating layout.
Regenerating model.
Command: Press ENTER to continue:
Command:
Thanks for the example...
I just found out that if you create a script that opens the drawing you want and use a macro to open up that script it woulds like a charm!
Create a new text document (txt) and use the following
open
"C:\ExampleFolder01\ExampleDrawing01.dwg"
y
y
save that text document as a
.scr
file and save it somewhere you can find easy e.g. c:\New Text Document.scr
than create a marco with the following;
^C^CSCRIPT "c:\New Text Document.scr"
There you go =]
