hi to all, im very interested in lisp routine because i am using autocad as part of my job... i would like to create an estimates using autocad. Is there a lisp that when i select a rectangular ot any closed polygon it will prompt a thickness then it will give a volume? example, area = 20, t = 0.1, volume = 2. then selecting the point where i will put the volume. thnx in advance... more power
Some people are so ungrateful and demanding at the same time. Makes you wonder doesn't it?
Exactly - that is the last bit of help I provide for him...
