on a 3d car project i am working on i drew up the outline then extruded it based on that i traced over everything and deleted the extrusion marks now as i try and add gradient and hatch it never turns out right how can i do this???
Can you show us your problem anyway?
Why gradient and hatch and not materials?
i know it isnt to complicated or nice looking but its what i have... its like i cant put a color to a face cause they are all lines
CAR2.0.dwg
use the "3dface" command and follow the point (corners) around your side window and see if this helps. Good luck and welcome aboard :)
any hints on curves 3dface is amazing hah
There used to be some nice 3D face commands in ACAD but solids might be a better choice these days.
I added two faces to your car for you to see. These were easy since they were flat and not curved.
