KiLLiNG-TiME Posted June 1, 2010 Share Posted June 1, 2010 How can i rotate an annotative block at one scale & not another ? I cannot seem to get it to work, i can move a block into a different location for each scale using the grip but when i rotate both scale's of the block rotate !!! Quote Link to comment Share on other sites More sharing options...
alanjt Posted June 1, 2010 Share Posted June 1, 2010 How can i rotate an annotative block at one scale & not another ?I cannot seem to get it to work, i can move a block into a different location for each scale using the grip but when i rotate both scale's of the block rotate !!! vla-put-rotation will NOT update other annotative scales. You could just create your own. If you have Express Tools, you could use acet-ss-drag-rotate to make life really easy. eg. (acet-ss-drag-rotate <selection-set> <base-pt> [<prompt>] [<hilight> [<cursor>]]) Quote Link to comment Share on other sites More sharing options...
KiLLiNG-TiME Posted June 1, 2010 Author Share Posted June 1, 2010 Thanks for reply Quote Link to comment Share on other sites More sharing options...
alanjt Posted June 1, 2010 Share Posted June 1, 2010 You're welcome. If you are using vla to set the rotation, and want each Annoscale option reset, you can use the AnnoReset command. Quote Link to comment Share on other sites More sharing options...
