MR MAN Posted August 30, 2008 Posted August 30, 2008 Is There Any One Know Programming Of Planar Surface And 3dmesh? Quote
ReMark Posted August 30, 2008 Posted August 30, 2008 What is it that you are trying to do by way of programming? Or are you asking how the commands work? Quote
MR MAN Posted August 30, 2008 Author Posted August 30, 2008 I Need 3d Mesh Work Like Planarsurf But Keep Properties Of Each Mesh As It Is (attachment File Explain What I Needexactilly) So If There Are Any Way To Do That I Will Be Very Pleasure. Thanks Remark. SURFACE AND MESH.dwg Quote
rocheey Posted August 30, 2008 Posted August 30, 2008 I looked at the drawing, yet I still dont understand what you are asking. Both are 2d planar objects; and im not sure what you mean by 'keep the properties' Quote
MR MAN Posted August 30, 2008 Author Posted August 30, 2008 iam sorry i will explain more shape on the left make with planarsurface so when i put planarsurface in command line and then select polyline object the area inside the shape divide like 3dmesh put when i explode it it will be disappear that mean it is not 3dmesh. My question is how i make this shape make with planarsurface look like 3dmesh which mean i can explode it to many meshs? i know that you say why? because iam civil engineer and i use sap2000(structural program) which need 3dmesh for design?and i have big areas which need to make with 3dmesh command so it take alot of time to make it with 3dmesh put planarsurface make it very quick just click on polyline and it divide inner area. thanks alot. Quote
