tirm Posted August 30, 2008 Share Posted August 30, 2008 I have a problem with double-click editing. Although i have the double-click editing in the options chekced it doesn't work. If i double-click on the text it only selects the text. What do i need to do for fixing this problem? Quote Link to comment Share on other sites More sharing options...
Strix Posted August 31, 2008 Share Posted August 31, 2008 is it actually Mtext and not Dtext? Quote Link to comment Share on other sites More sharing options...
e.mounir Posted September 1, 2008 Share Posted September 1, 2008 I have this problem before and I fixed it by - close the AutoCAD , from start >>all programs>> Autodesk>>autocad2008>> Migrate custom settings >> select autocad2007 Quote Link to comment Share on other sites More sharing options...
nocturne00 Posted September 1, 2008 Share Posted September 1, 2008 How do you mean? if you want to double click on a text you want it to prompt the mtxt window or text window for editing right? and not just select it? Quote Link to comment Share on other sites More sharing options...
e.mounir Posted September 1, 2008 Share Posted September 1, 2008 Some time when you double-click on the text it only selects the text only and that what I mean But if you want to Displays the In-Place Text Editor for creating and editing text used DTEXTED commend Quote Link to comment Share on other sites More sharing options...
nocturne00 Posted September 1, 2008 Share Posted September 1, 2008 I have this problem before and I fixed it by - close the AutoCAD , from start >>all programs>> Autodesk>>autocad2008>> Migrate custom settings >> select autocad2007 I think that only works when you've got a previous version of CAD installed. I remember this happening to me once. ill bet this issue started maybe whilst you were rotating or aligning viewports, sometimes when you end MVSETUP command prematurely with ESC your ONSNAP settings reset and also your selecting style. Go to OPTIONS>SELECTION>SELECTION MODES> check"Noun/Verb Selection" Give me a heads up if it solves it Quote Link to comment Share on other sites More sharing options...
e.mounir Posted September 1, 2008 Share Posted September 1, 2008 Yes you are right Quote Link to comment Share on other sites More sharing options...
