Block Counter (Includes Dynamic Blocks)
Lee Mac
Thanks.
Ok, so from your error I'm guessing that:
(cdr (assoc 70 (tblsearch "BLOCK" <BlockName>)))
Is nil.
I'm not sure why this should be, as the block should always have a group 70 DXF value - are you using any 'special' blocks (non-standard)?
As a quick fix, change:
                   (if (zerop (logand 45 (cdr (assoc 70 (tblsearch "BLOCK" (setq n (BlockName obj)))))))
                     (setq l (assoc++ n l))
to:
                   (if (setq n (BlockName obj))
  • Replies 131
  • Lee Mac
    58
  • The Buzzard
    7
  • autolisp
    5
  • piscopatos
    4
Posted Images
i tried this quick fix, it doesnt give nill anymore but table comes back empty.
i dont know whether i got non standard block or not but if there is i guess those non standard blocks might have come when i installed autocad mep.
thanks for your effort lee, u r a bless to this comunity
Lee-
This lisp is awesome!! The previews are great, this will help with some basic estimating too!!
Keep up the great work! I sure have a lot of learning to do when it comes to this stuff!
Kat
Lee-
Kat
Many thanks Kat, I'm glad you like it :)
Lee
  • 4 weeks later...
Dear Sir,
Some Error on lisp please chk
See Attched file
Command: ap APPLOAD CountV1-2.lsp successfully loaded.
Command:
ø¤º°`°º¤ø  Count.lsp ~ Copyright © by Lee McDonnell  ø¤º°`°º¤ø
  ~¤~          ...Type "Count" to Invoke...            ~¤~
Command:
Command: count
Select Blocks to Count <All> :
Block Name..............................|...Count
Tree-Jambhul............................|.......1
Tree-Piple..............................|.......2
Tree-Umber..............................|.......1
Tree-Wadh...............................|.......1
rpole...................................|.......1
t15b....................................|.......2
Table? [Yes/No/Settings] <Yes> :
** Error: no function definition: nil **
Tree Inventary 16-12-2010.zip
This is the first time such a bug has been reported - could you identify in the VLIDE on which line the code crashes?
To do such, type VLIDE at the AutoCAD command line, then:
  • Open my program (Ctrl+O)
  • Debug > Break on Error (ticked)
  • Load my program (Ctrl+Alt+E)
  • In AutoCAD: Run the program 'til it crashes
  • In VLIDE: Debug > Last Break Source
  • Copy/Paste the highlighted code segment here along with the relevant error message.
  • Reset the Error (Ctrl+R)
  • Untick the Break on Error (if desired).
Lee
Lee
Dear Sir,
below Line error
                 (if (is64Bit)
                   vla-SetBlockTableRecordId32
                   vla-SetBlockTableRecordID2
                  tObj row 0 acBlockCell
                 (GetObjectID (Itemp blks block) doc)
                 t
Ok, I would assume that the vla-SetBlockTableRecordID2 function perhaps doesn't exist in ACAD 2006 (the version displayed on your profile).
I'll look to update the code in future, but for now, try changing:
to
Lee
to
Lee
Dear Sir,
Update code but some error
error on same line
(if (is64Bit)
t
** Error: Too many actual parameters **
that is very nice. how about the ability to count the view states of a dynamic block?
Thanks Mark, I think that question about dynamic blocks has been asked in the past - I could look through the Dynamic Block properties of the block but how does one determine which dynamic properties are view states? I need more experience with dynamic block manipulation really :oops:
