VVA
CopyBlock - COPIES THE SELECTED BLOCK WITH A NEW NAME
VVA
;;; CopyBlock - ROUTINE TO COPIES THE SELECTED BLOCK WITH A NEW NAME
;;; Work (i HOPE) with dynamic block
;;; Created by Vladimir Azarko (VVA) 2010-06-02 ([email protected])
;;; Credits to Tony Tanzillo, Joe Burke and Vishal Gonsalves for sharing their lisp copyblock.lsp
;;; http://discussion1.autodesk.com/forums/thread.jspa?messageID=6182594
;;; http://discussion.autodesk.com/forums/thread.jspa?threadID=767010
;;; posted http://forum.dwg.ru/showthread.php?t=36419
Any suggestion is welcomed
CopyBlock-VVA.lsp
Share this post
Link to post
Lee Mac
Interesting approach Vladimir, I must say. I wouldn't have thought to create a temporary document to house the block definition so that you could change its name. I probably would have created a new Block Definition with the new name, and then just used CopyObjects to copy everything contained in the old definition into the new one... but nice code all the same.
Lee
Share this post
Link to post
Lee Mac
Perhaps in Vanilla it might look like this - (standard blocks only of course):
(defun CopyBlock ( old new / tdef )
 ;; © Lee Mac  ~  07.06.10
 (if (setq tdef (tblsearch "BLOCK" old))
     (entmake (subst (cons 2 new) (assoc 2 tdef) tdef))
     (mapcar 'entmake (mapcar 'entget (GetObj (tblobjname "BLOCK" old))))
     (entmake (list (cons 0 "ENDBLK") (cons 8 "0")))
 new
(defun GetObj ( e )
 (if (setq e (entnext e)) (cons e (GetObj e)))
(defun c:test ( / ent old new )
 (if (and (setq ent (ssget "_+.:S:E:L" '((0 . "INSERT"))))
          (setq ent (entget (ssname ent 0)))
         (while
             (setq new
               (getstring t
                 (strcat "\nNew Block Name <Copy of "(setq old (cdr (assoc 2 ent))) ">: ")
             (cond ( (eq "" new) (setq new (strcat "Copy of " old)) nil)
                   ( (or (not (snvalid new)) (tblsearch "BLOCK" new))
                     (princ "\n** Block Name Not Valid **")
         new
   (if (CopyBlock old new)
     (entmod (subst (cons 2 new) (assoc 2 ent) ent))
     (princ "\n** Block Copy Failed **")
Share this post
Link to post
Guest kruuger
please see attachment how the amateur (Me) play with this.
i like your idea with DCL.
i think that only one thing is missing. Check to see if block is an Xref.
kruuger
Block Clone.lsp
Share this post
Link to post
alanjt
Very cool Vladimir! I'm sure it will be useful to many.
BTW Lee, your new block will not be annotative if original was.
Share this post
Link to post
Lee Mac
Yeah, it won't process Dynamic blocks either - "standard blocks only"...
Share this post
Link to post
alanjt
Just putting the information out there for the world.:wink:
Share this post
Link to post
VVA
... to create a temporary document to house the block definition so that you could change its name. ...
Lee
Because of the dynamic blocks I did. This idea, I spied a Vishal Gonsalves (see the references in # 1)
Share this post
Link to post
Lee Mac
I noticed - a nice idea all the same. :)
Share this post
Link to post
alanjt
Had a use for this today and just wanted to say thanks; saved me a little legwork.
Share this post
Link to post
