GilHuff Posted June 9, 2010 Posted June 9, 2010 I would like to rotate the whole drawing including the north orientation so that the property line (which is not north) is parallel to the long side of the sheet. How do I do this? I am working in AutoCAD 2000 Land Development. Quote
H'Angus Posted June 9, 2010 Posted June 9, 2010 I would like to rotate the whole drawing including the north orientation so that the property line (which is not north) is parallel to the long side of the sheet. How do I do this? I am working in AutoCAD 2000 Land Development. You can rotate a viewport, so that the modelspace objects stay put but the view on the layout will be rotated. To do that use the mvsetup command and the options 'Rotate view' and 'Align viewports'. Is that what you mean? Quote
