muck Posted June 10, 2010 Posted June 10, 2010 Is there a AutoCAD field that would read the drawing file name without giving a directory path. Is there a way to give file name only. Thank you, Quote
Nardino Posted June 10, 2010 Posted June 10, 2010 you can use this rtext, works for me $(getvar, "dwgprefix") Quote
Hippe013 Posted June 10, 2010 Posted June 10, 2010 Type Field Then under Field Names: Select FILENAME Then select radio button FILENAME ONLY Quote
