Hello,
I don't speak english but I will try to explain my problem.
I am trying to measure angles bigger then 200 gons (180 degrees), but i can't.
Can i change the settings somewhere so i can measure angles of 300 - 400 gons.
Command: DIMANGULAR
Hit enter pick vertex then end points of the two angles as such:
KC
kencaz your animation is worth a thousand words! Great work as always.
I was goin' to reply, yada, yada, yada.
Hi,
Good animation ! Kencas. I am curious, what kind of software do you use it ?
Have a good day
Pascal
