Making VBA programs run by Hot Keys or menus
muck
 Share
Is it possable to make a VBA Program start running using a menu pick or a hot
key. What is the easyest way to make a VBA program pop up in AutoCAD 2010
Thank you,
Here is a code example just put it in your autoload file
(defun C:vbadrn ()
(vl-vbaload "S:/AutoDESK/VBA/vbadrains.dvb")
(vl-vbarun "pitscheduleupdate")
you can either type vbadrn or assign it to a menu ^c^cvbadrn or again in the menu ^c^c(vl-vbaload S:/AutoDESK/VBA/vbadrains.dvb") (vl-vbarun "pitscheduleupdate")
I guess by your question that your running a VBA that some else has written, to answer though the question there is two steps.
1 Load a VBA program it can contain many different routines within it. "VBDRAINS.dvb"
2 Run a particular sub routine within the VBA program "pitschedule"
If your VBA is already loaded as part of your statrtup proceedure then you only need step2 to run.
 Share
