How to fix to work with custom UCS?
Guest kruuger
Hello
I have a problem with my lisp routine.
When i work with world UCS everything is fine but very often i work with rotated UCS and then lisp doesn't work correct.
Probably i need to use trans function. I try this but without good result.
Please help
Thanks
kruuger
Xlinedim.lsp
You will need to transform your user-selected points from UCS to WCS, :
(trans <point> 1 0)
Guest kruuger
aaa, it was so simple :oops:
thanks Lee
kruuger
Guest kruuger
i noticed one thing. whem i rotate UCS with this lisp:
(Defun C:UU ()
 (setq osmode_hold (getvar "OSMODE"))
 (setvar "OSMODE" 512)
 (setq PT1 (getpoint "Select LEFT side of OBJECT which should be horizontal"))
 (command "_UCS" "OB" PT1 "PLAN" "CURRENT" "")
 (setvar "OSMODE" osmode_hold)
);UU
and i try my Xlinedim then even with trans command xline are drawn wrong (they only worked at defined UCS North East, West, South)
What i can fix?
thanks
I haven't properly looked at your LISP, but you will have to acount for the UCS rotation by looking at the direction of the UCS X-Axis (UCSXDIR).
Guest kruuger
great thanks
i need to figured out this.
kruuger
