peterg Posted June 19, 2010 Posted June 19, 2010 I need to apply a scale to a viewport, the scale is 1:50, is the command zoom value 0.2 also need to know how to lock viewport, a bit lost there. :oops: Quote
rkmcswain Posted June 19, 2010 Posted June 19, 2010 Switch to MS inside the viewport, then Zoom>1/50XP To lock, select viewport, right click, it's on the context menu -or- select viewport, change in properties -or- use the MVIEW command. Not sure if locking viewports was available in 2007...? Quote
