Hi I used to use the Dimscale to set the scale of the drawing to control text height and linetype scales which worked well.
I was thinking about putting a lisp together to do this but I am not shore how to change the Dimscale when changing from paperspace to a model view port?
Any thoughts
cheers
Hi thanks
That works from PS to MS but not the other way round. I will give it a go to improve my lisp.
Cheers
It works as intended for my use. When I work most of the time it's in a layout tab; when in PS, it's always at 1:1, dimscale=1. So when I switch from MS to PS, it sets the dimscale to 1; when switching from PS to MS, it sets the dimscale= to the inverse of cannoscalevalue.
If you have other requirements feel free to edit as you like.
