Hi folks,
As the title suggests i'm looking for the vlax-create-object name for Winsock.
Any help will be appreciated
Cheers,
Ollie
Hi Ollie,
I thought it was:
MSWinsock.Winsock
But I could be wrong...
This should get a list of all ProgID's
(defun GetProgIDs ( / *error* regPath file id ofile lst )
 (vl-load-com)
 ;; Lee Mac  ~  17.02.10
 (defun *error* ( msg )
   (and ofile (close ofile))
       (princ (strcat "\n** Error: " msg " **")))
 (if (setq file (getfiled "Output" "" "txt" 1))
     (foreach desc (vl-registry-descendents
                     (setq regPath "HKEY_CLASSES_ROOT\\CLSID"))
       (if (setq id (vl-registry-read
                      (strcat regPath "\\" desc "\\ProgId")))
         (setq lst (cons (vl-princ-to-string id) lst))
     (setq ofile (open file "w"))
     (mapcar '(lambda ( x ) (write-line x ofile)) (acad_strlsort lst))
     (setq ofile (close ofile))
Lee: You are epic; I have been searching for the above function since birth :)
