firavolla Posted June 23, 2010 Posted June 23, 2010 Ok guys, so, besides Lisp, I'm also working with VBA for Autocad. Imagine this. I have a form with 1 textBox and 2 buttons (ok, cancel). When the user clicks ok, the numeric value inside the texBox is stored in a variable let's say 'A'. Then the form is hidden, the user clicks inside the draw space for a start point of the line - for this I use getpoint. I then set a second point at a distance of A (vertical dirrection) from the start point and want to draw a line. What I have done is something like Private Sub CommandButton1_Click() 'Declare the variable used for getting the info from the textBox Dim ALength As Double 'Get the value from inside the textBox ALength = CDbl(TextBox1.Text) 'Point declaration Dim p0 As Variant Dim p1 As Variant 'Hide the form UserForm1.Hide 'Get point from user p0 = ThisDrawing.Utility.GetPoint() 'Set second point p1 = p0 p1(1) = p0(0) + ALength 'Draw the line Dim p0p1Line As AcadLine p0p1Line = ThisDrawing.Application.ActiveDocument.ModelSpace.AddLine(p0, p1) End Sub The problem is, it does not work. First of all, i have problems with getPoint, but i think i can get around them. Secondly, the 2nd point should be at ALength away from the first on the Y axis. This does not happen..If p0(1) is let's say 50 and ALength is 100, p1(1) should be 150, no? In my case it's 66 or 120 or 111.23. Why is that? Lastly, when it gets to p0p1Line=....I get an error (91) saying it's value is NOTHING, but if i click END, i still get a line drawn in ACAD. Any HELP? Quote
MSasu Posted June 23, 2010 Posted June 23, 2010 'Set second point p1 = p0 p1(1) = p0(0) + ALength Please take care that you are adding the displacement to coordinate X of p0 point. Shouldn't your code be instead: 'Set second point p1 = p0 p1(1) = p(1) + ALength Also, since it is about an object should use: Set p0p1Line = ThisDrawing.Application.ActiveDocument.ModelSpace.AddLine(p0, p1) Regards, Quote
