gilsoto13 Posted June 23, 2010 Posted June 23, 2010 Hi, All As suggested by tiger. This routine will add 4 control points to selected mtext, in most cases it will fit selected mtext objects to their text string size, taking columns and rows size to fit the new 4 control points. In some cases it will make mtext to a one row mtext, but the 4 control points will help you to fit them to the desired width manually. This is for sure duplicated in another thread or forum, I grabbed it from an autodesk discussion group, and it's made by Rogerio Brazil. You may also like smt2 to stript mtext without options (delete forced properties from mtext using mtext edit dialog box). This one is from Hispacad, give it a try. mw.lsp smt2.lsp Quote
