Burner Posted June 23, 2010 Posted June 23, 2010 For some reason I cannot change the layers on any of my objects (also my delete button does not work). Nothing is frozen and everything is turned on. The last thing I remember doing was using MVSETUP to rotate views in a viewport. Could this have happened during this process? Please advise... Quote
Burner Posted June 23, 2010 Author Posted June 23, 2010 Okay, I can change layers for my objects via the layer properties menu. In the past I have changed layers through the layers panel under the home tab. this does not seem to work anymore. Is there a way to reactivate this option? Quote
nukecad Posted June 23, 2010 Posted June 23, 2010 Sounds like PICKFIRST or PICKADD? See the links on Cad64's signature. Quote
rvpas Posted June 23, 2010 Posted June 23, 2010 Oups ! just nukecad reply before From autocad help Controls whether you select objects before (noun-verb selection) or after you issue a command. 0 -->Turns off PICKFIRST; you select objectsafter you issue a command 1 -->Turns on PICKFIRST; you select objects before you issue a command Quote
