whippet Posted June 24, 2010 Posted June 24, 2010 Hi Ppl Is there a way I can turn off 3D in autoCAD and work only with 2D A few jobs I open have 3D elevations. Its a nightmare Thanks Lyle Quote
Tiger Posted June 24, 2010 Posted June 24, 2010 No, not a on/off-switch. When I get files with points/lines in 3D I almost always spend some time taking a copy of the drawing and get everything down to 2D-format. I do this mostly with FLATTEN, but also some with command CHANGE > Elevation. It can take a lot of time, but usually I save that time in the end with files that take less time to open and I know the distances are correct. Quote
rvpas Posted June 24, 2010 Posted June 24, 2010 Hi, See flatshot Home tab/Sections tab/Flatshot or type flatshot bye Pascal Quote
ReMark Posted June 24, 2010 Posted June 24, 2010 I'd try the Flatten command first. I'm not so sure you want to use the Flatshot command. I'd use the Change > Elevation command next, if Flatten doesn't do the job, as Tiger suggested. Quote
Tiger Posted June 24, 2010 Posted June 24, 2010 From Help: FLATSHOT: The edges of all 3D solids, surfaces, and meshes are projected line-of-sight onto a plane parallel to the viewing plane. The 2D representations of these edges are inserted as a block on the XY plane of the UCS. This block can be exploded for additional changes. If you have complex 3D-shapes then Flatshot would be the way. I don't think I would use it for just linework, but it might be me that is backwards. I may have to try it next time. Quote
