Cholomanchuten Posted June 24, 2010 Share Posted June 24, 2010 I guess you know me from intrincate questions down the forum list. New one: I want to save a Block and manipulate the options of AutoCad so that i can insert that block from any drawing, not just the drawing i created it. Also. i save a block as a .dwg, then i open it with the Design Center and it doesn't recongnize it as a block, it recognices it as a drawing so i can't insert it that way.... I want to use the comand insert, and, when i name the block ("example: CUBE") Autocad inserts that CUBE, but i didnt have to previously browse to find the dwg. Anything? Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 24, 2010 Share Posted June 24, 2010 Blocks saved to your hard drive as a dwg file can be inserted into any drawing in any number of ways (Design Center, macro, insert command, auotlisp, dragged off a tool palette, etc.). Quote Link to comment Share on other sites More sharing options...
Cholomanchuten Posted June 24, 2010 Author Share Posted June 24, 2010 Yep, but i'm specifically interested in block insertion by Script. You know, i have done a lot of things through script in many drawings, but i never had a command that opens a window (like the "insert" command).. so the script to insert a block is unclear.. i mean.. where do i put the path to the block? Quote Link to comment Share on other sites More sharing options...
dbroada Posted June 24, 2010 Share Posted June 24, 2010 you can't use dialogue boxes (easily) in scripts. To insert a block you need to use the -INSERT (note the - symbol) to use the command line version. You set up search paths on the first tab of the options box. Quote Link to comment Share on other sites More sharing options...
ReMark Posted June 24, 2010 Share Posted June 24, 2010 Insertion by script. Ahhhh...now i see. That's a pertinent piece of information. If one were doing it by a macro it would go something like this: ^C^C-insert;c:/dwg/myblock.dwg; I'm sure the script file should be somewhat similar give or take a character or two. Quote Link to comment Share on other sites More sharing options...
