CalypsoArt Posted June 25, 2010 Posted June 25, 2010 This is a recent happening. Any time I select a dimension for any reason, the properties pane takes several seconds to fully display. If I need to scroll down the pane takes seconds again to display. If I then alter a property, it takes a few seconds to change on screen. Any ideas? Not a major issue, but annoying to wait. Sager NP8760 i7 820 4mb DDR3 1333mhz Win7 Pro 64 nVidia GeForce 285m GTX Quote
CalypsoArt Posted August 27, 2010 Author Posted August 27, 2010 Bump. Any one experiencing this? Seem to have recently got worse. If I select any dimension, my cursor locks for about 5 seconds before I can move/do anything. Seems to send the machine into a display slow down. If the properties docker is open it takes those 5 seconds to refresh and display all the properties. Same delay if I want to scroll down within properties. I'm suspecting this is a video driver related. nVidia Geforce Go 285GTX Quote
toberino Posted August 27, 2010 Posted August 27, 2010 Do you have any pdf's imported in? I have realised that any time there is a pdf imported in to the drawing it created an extremely painful lag in the program. Quote
CalypsoArt Posted August 27, 2010 Author Posted August 27, 2010 Nope. Quite right though. I find PDFs quite problematic so I avoid them. Quote
ReMark Posted August 27, 2010 Posted August 27, 2010 Is Update 1 for 2010 installed? Wait a sec. You mention 2010 but your profile says 2008. Which one are we talking about here? Quote
CalypsoArt Posted August 27, 2010 Author Posted August 27, 2010 We moved to 2010. Don't know about the update. Will check. Quote
