ReMark Posted July 1, 2010 Share Posted July 1, 2010 Your loft command appears different than mine. I notice an option for Settings. What is that all about? Quote Link to comment Share on other sites More sharing options...
mitchellrodhous Posted July 2, 2010 Share Posted July 2, 2010 I think the Loft command made an real big upgrade in cad2011... total different from 2010... but u get used to everything.... Quote Link to comment Share on other sites More sharing options...
ovzka Posted July 2, 2010 Author Share Posted July 2, 2010 it is a good upgrade but should have the option to do solid as before and separate the option of the new "solid":P Quote Link to comment Share on other sites More sharing options...
kencaz Posted July 2, 2010 Share Posted July 2, 2010 it is a good upgrade but should have the option to do solid as before and separate the option of the new "solid":P Yeah... I pulled this from a blog somewhere. [sNIP] "A lot of new changes are not immediately apparent- for instance the loft command has been overhauled to allow for surface creation. Previously, the dialog box came up automatically, now you have to use the Settings option to make it come up. Source: http://wlecouteur.blogspot.com/2010/04/autocad-2011.html I can see where this can become confusing... KC Quote Link to comment Share on other sites More sharing options...
ovzka Posted July 2, 2010 Author Share Posted July 2, 2010 well the way the command works is not my problem the problem is the result that any given proses gives Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 2, 2010 Share Posted July 2, 2010 Thank you for the bit of information kencaz. I guess when I finally get around to loading 2011 I'll have to check out those settings myself. Why did some programmer decide to go ahead and change the here-to-for default for the loft command from solid to surface? I don't recall anyone asking the users for their opinion. Quote Link to comment Share on other sites More sharing options...
