Adding dimensions to an Assembly
Hi there,
Does anyone know if its possible to add a dimension in an assembly and animate this in Inventor studio? I know I can create a sketch in the assembly and add a dimension there but when I go to render the animation, it disappears.
I have 2 moving parts I want to add a dimension between them and show that this dimension increases over time, as they move in the animation.
Any help is appreciated.
Jonny
Have you tried to just use a Drive Constraint and show the update happening? When you use Render in Studio you will not get sketch visibility. Perhaps if Drive Constraint doesn't work for you, you can try a Preview:No Render option in Studio. If neither of these work, buy a screen capture program.
