Nardino Posted June 30, 2010 Posted June 30, 2010 I was wondering if anybody knew how to keep the host drawing of an external reference file with the layers exactly the same as the external reference file. I hope this clear. Basically when I start a new drawing, I have a template with all layers built in. When this model drawing is used as an external reference file, it brings in all the used and unused layers. As I populate this model drawing I remove/purge all the not-used layers. When I update the host drawing, the unsused layers are still there and I cannot remove them. What I have been doing is to detach these external files, purge the host drawing and then re-attach the external file again. Any fix to this???..........thanks all Quote
designerstuart Posted June 30, 2010 Posted June 30, 2010 wouldn't you be better off bringing in your standard layers in a block? all layers (used or unused) in the xref will come through to the host while it is attached. as a block the layers become part of the host drawing, and can be purged if required. hope this makes sense. Quote
