danielford1979 Posted September 4, 2008 Posted September 4, 2008 I am using AutoCAD LT 2007, can anyone tell me if there is a way to extract data from a CAD drawing so I can download to an EDM in order to set out points on site rather than manual input them to the EDM? Quote
eldon Posted September 4, 2008 Posted September 4, 2008 Unfortunately for you, you have LT which doesn't support Lisp. There have been some excellent routines written by ASMI, but you will not be able to use them. Probably the easiest thing for you to do is to draw a polyline between your points in order, then do a List, and copy from the text screen into a text editor like Wordpad. With some manipulation, you can end up with a file suitable for uploading to an EDM Quote
