I have a problem with my right click menu. Before when I would select an object in the drawing and right click and select say move the object would be ready to be moved. Now when I do it the move command is invoked but it asks me to select objects to move and so I have to reselect the object before moving...
How do i get back to the original state?:shock:
Thanks
Seems that your PICKFIRST system variable is set to 0; should set it to 1.
Regards,
Thanks that did the job alright!
You're welcome! Glad to help you.
Regards,
