I am currently using AutoCAD 2005 (which I've never worked in). I have to bring in a couple of images which I have done so by selecting "raster image". All is well. Comes in just fine. I then select "imageframe, off" and the lines disappear. So, I print to PDF (which is how this company does everything. Nothing is actually plotted directly from AutoCAD to a printer. Once the PDF is ready, there is no visible image frame, but once I print it to a printer, the frame appears on the top and right side of the image. It doesn't seem to matter what layer I am on either. Can someone please help me? I'm stumped :?
Can you post a sample file? Seems like it may be an issue between the printer and the PDF file rather than an issue with cad...?
