Can Filenames be exported to a file from selection set manager
AutoCAD 2010
Can Drawing Filenames be exported to a text file form selection set manager
in the order that SS manager list them? If not. can a program be made to
make a selection set manager create a text file with drawing files name in it?
Thank you,
I don't know if this will help you but you can Insert Sheet List Table into a drawing, which will give you the list of drawings, dwg number, etc. in a table in a drawing.
I need to get a text file with a list of drawing files in it. I use some batch
rountines in VBA that reads a file list with drawing names in it. I would
like for it to follow SS manager file list if I could.
Thank you,
