Fixo, you're the best.
XPOINTS routine works perfectly.
How can change the text and blocks inserted into autocad as to be fifty times greater? What should be changed in lisp to make this change?
Once again thank you.
Samuel
  • Replies 24
  • fixo
    10
  • SCaldeira
    7
  • KAC
    4
  • Hippe013
    1
Posted Images
Samuel
Hi Samuel,
take a look closely at this code snip:
(setq blkobj (vlax-invoke-method
     acsp ;<--active space
       'InsertBlock
  (setq inspoint (vlax-3d-point(list (cadr item) (caddr item) 0))) ;<-- insertion point
 blkname ;<--block name
  1. ;<-- XScale
  1. ;<--YScale
  1. ;<-- ZScale
  0. ;<-- Rotation angle in rad
Easily to change it to your needs
Thanks for the kind words
Cheers :)
~'J'~
Thanks my friend
Cheers :):):):)
Thanks my friend
Cheers :):):):)
You're welcome
~'J'~
Dear Sirs
Please I want a lisp for Landdesktop To plot me
X-Aces Logarthmic Scale
Y-Aces Linear Scale
Thank you
